brucechase
I thought I would chime in here. I do the exact same thing with tires merging onto a main conveyor belt. There is no fancy array or tables to keep track of what is where. The photoeyes on the main conveyor are a little further upstream of the induction point (at least 1 bag length). As a bag moves down the main conveyor, there is a timer actuated by that photoeye that give the 'hole' size. Based on the conveyor speed, I've got it down to the largest tire size (to be the same as a bag). If the hole is big enough, then after a slight delay of the tire passing the photoeye and I induct it onto the main conveyor. Be careful of using retentive timers because of the startup of the conveyor system if on a VFD or softstart (which I suspect is the case). The ramp up time messes with the hole size.
If you want to not starve the last counters, then use a set of extra delay timers in the 1st inductors such that if there is luggage on the last of the counters, then I add a delay equal to 1 or 2 holes sizes depending on how long those photoeyes are block.
Hope this wasn't confusing, I just thought it was getting a little more complicated than it should.
