sprek
I am doing a new project were I need to keep track of bad parts( basically upside down) on a conveyor that I want to keep tracking on if someone changes the belt speed.
I have Two sensors that trigger at the same time for bad part
also I have an encoder with only the a-phase hooked up
I have never used an encoder before and am not sure were to start. What would be the best way to set this up? Do I use the encoder to run a shift register and if so what would the best way of thinking during programming? I know the sensors are 778 pulses away from the reject chute. Do I need to figure this number into the setup or do I need to think differently
I could use some direction on how to program this to work.
I take pride in doing new things and I challenged myself to figure this out
I am using the Eaton ELC-PC12 plc. I am not wanting to have the program written for me but to help me learn the way to do this correctly
