Copy of programme
gmultani52
Oct 2003
75
Hi, Can I copy a ladder logic programm from a work station, and load in my laptop which has software RSlogix 500 and rslinx.
do you mean you want to upload a PLC program from a PLC to your laptop? If you have the right software and right cable then should be no problem for SLC.
I'm not sure I understand what you are asking for, so here are two answers:
1. You have a PC that is connected to your PLC. The PC has the off-line file with documentation that runs in the PLC. You want to take this off-line file from the PC, and transfer it to another PC - your laptop. Both PC's are currently running Logix 500.
Absolutely - just copy the .RSS file onto a floppy and copy that to your laptop.
2. You have a PC that is connected to your PLC. This PC is running Logix 500. Your laptop does not have Logix 500, and you want to install Logix 500 there.
In this case, you should get your installation CD and install the program onto your laptop (I wouldn't try copying since the registry will be problematic). Then you need to install the activation to run the program. This can be transferred from one PC to another using the EVMOV utility that is included on your master disk.
If I misunderstood what you are trying to do (or you need more clarification), please let us know.
Marc
Can someone tell me how to copy programme from one PLC to another with all the data entered in it. e.g. the register values counter limits etc...
1,267
I have 2 7cp476 plcs. How can I copy one of them and install it somewhere else?
75
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
142
Hi everyone I'm in a bit of a conundrum, I've been trying to get this HMI on our machine and I am unable to retrieve it. Device Delta Model...
901
Hi I have a Melsec FX1S-20MR, which has been programmed. I would like to copy the program to a new FX1S-20MR? What are the possible ways to do...
630
