Copy & paste between projects in TIA 15 WinCC
mrkvak
Jan 2019
Liberec
20
Hi all,
I am a bit crazy from behavior of WinCC (actually TIA 15). I have two opened projects and I need to copy some screen items (buttons, ...) and paste them into second project (second instance of TIA portal). But if I paste into another project it is always aligned TOP and LEFT on screen. So the original position is lost.
One solution is to copy complete screen and then copy just inside one project - which works and possition is kept the same.
Does anyone know how to easily copy and paste and keed the same position of items?
Thanks a lot ...
When you copy from referenced projects, the position stays the same..
View->turn on Referenced projects.
There, open your project to copy from..
As far as I know sometimes in such cases, you can't just copy and paste. If you have any doubts you can always get in touch with professionals from some development company, you can search for a good one. I usually prefer to deal with https://echoua.com this company. You can also try their services.
Good Morning. Has anyone successfully copied and pasted routines and or tags between virtual machines. I am using RSLogix 5000 V15 on one VM...
723
To copy a tag name in S5k we can, *right click an instruction *open the edit properties dialog box *and then copy the tag name text If we...
1,549
Im successfully using Modbus Poll to read and write to a remote Freewave IOEX-4422 slave device. However I am hitting a wall getting the ladder...
1,359
Hello Guys, I have just upgraded an older machine from a old processor to a new studio 5000 processor (1756-L83ES). For some reason when I am...
3,652
This is a real simple interface problem. Typically when I'm developing in ladder I will Ctrl+C an instruction and Ctrl+V, the new instruction will...
1,680
