Correcting Analgo Sensor Offsets in PLC Program
Jieve
Feb 2012
USA
274
Curious, is it common to program in offsets to calibrate/correct analog sensor readings in certain applications? As an example, I have a couple flowmeters on a simple system that continuously read slightly below zero when the system is switched off (no flow), and their readings differ from each other. Is it desirable to zero these values in the program, or is it better not to do this?
I have a Micrologix 1400 with an 1762-IR4 RTD. I use it to read airbag resistance on seats on an assembly line. I am often getting into a...
1,207
Curious, is it common to program in offsets to calibrate/correct analog sensor readings in certain applications? As an example, I have a couple...
3,135
Hi all, splitting out from this thread because it's a somewhat different question to the original. I have to migrate some code from a Micrologix...
17
4,114
Hi everyone, I am working with micro850, a proximity sensor (FOTEK, PL-05P) and a 3DOF serial arm robot. I use MC_MoveRelative to control the...
62
Maybe a stretch to call this a PLC question, but it does connect to a PLC input. I have two German switches: Sick WL9LG-3P2232 And a...
113
