Countdown timer for Vijeo Citect 7.20
jmzhale
Sep 2016
Kentucky
Is there a way to created a countdown timer that would display when a trigger becomes true and go away when the timer reaches zero?
{DATE,20}{TIME,20}{EQUIPMENT_ID,20}{ALARM_NAME,80}{USER_ID,100}{ACK_DATE_AND_TIME,50}{ACK_STATUS,10}{COMMENT,10}
Hello,
I have configure some digital alarm and thats alarm i have to Log in SQL using cicode but when i am trying to this this it cant work please can any one help me for the cicode for alarm log in SQL.
in the SQL table i want
{LogDate}{LogTime}{EqId}{AlarmName}{AckDate}{AckTime}{Comment}
in which EqId is my plc name in string whatever i will deside.
please give me a sample of the cicode for this
regards,
Chetan Patil
+91 9637138565
Hello,
regards,
Chetan Patil
+91 9637138565
Hello,
regards,
Chetan Patil
+91 9637138565
Hello,
regards,
Chetan Patil
+91 9637138565
What has this got to do with countdown timers ?
You should start a new topic if its an unrelated question.
Hello all, I am working on an old machine that has a hydraulic filter that must be replaced every so often. When the filter needs changing, a...
1,563
So I'm fairly new to PLC programing. in my PLC class my task right now is to write some logic that uses a thumbwheel to set the timer thats...
29
4,320
I have an unwinding roll process. On a display (7 inch Comfort) is a timer that shows "Time to Splice" in seconds. In the PLC (S7-1500), this is...
2,377
Hi guys, Thought I might ask here if anyone knows, currently have tech support looking for a solution. I have a micro820 and wanting to...
2,624
I did not create the program but I have a weird countdown timer problem. it is user input, say it is set for 5 minutes; it will countdown to...
4,463
