Ron Beaufort
final exam is to remind me to prepare for my final test program i will be required to present and document
OK ... good enough story ...
if you need more help, consider posting the PDF file I sent you ... the forum members will be glad to give you a hand ... personally, I've got to run along now ...
incidentally, I remember changing the Preset in the Counter from 10000 to 5 ... I didn't want to run 10000 cycles to see how the program reacted ...
questions you need to consider:
(1) if you stop the auto cycle by pressing the stop button, do you want the Counter to reset? ...
(2) if the power to the system fails, do you want the Counter to reset? ...
be careful to follow the logic through for at least two scans after making any changes ...
HIGHLY SUGGESTED: get yourself a processor to play with if you intend to keep on in this trade ... you're NOT going to be able to get very far without a working system to play with ...
good luck with your studies ...
