counter program is this posible
bpreissner
Jan 2008
wisconsin
Using a sensor and one counter (preset of 6) I want count 6 bottles then energize a output.
The counter then resets to 0
When the second count of 6 is reached the output is de-energized.
I am using rslogix 500.
I'd use 2 counters. On Counter1.DN energize your output and enable the second counter. On Counter2.DN RESet both counters.
Sounds very much like a homework question. You've got more than enough information in the posts above to solve the problem - if you make an attempt and then ask for feedback on your efforts, you'll get a lot more responses than if you just ask for answers so you don't have to think too hard.
So I’m going to give you the benefit of doubt given that you’ve been a member of this forum for 8+ years now (I hope you haven’t been a student for that long). I’ve attached two PDF’s with how I’d do it. On uses a counter that goes to 12 and when it hits 6 an output is energized. I’m using a GEQ (greater than or equal) so from 6 to 12 the output is energized. The second one uses a counter that goes to 6 and uses the status of the output to turn it on or off.
Hello all, new on here, and relatively new to plc programming. I am trying to write a program which counts as it receives a cycle end input, and...
1,902
HI i newbies. i want make a simple program in cx- programming.. i have 4 sensor(detect the box). how to count the boxes that have presents..if...
2,478
Hi I need a sample program to use 1769-HSC High speed counter module to measure the pulses of an encoder (connected with HSC) over a specified...
11,966
Hi friends I am planning to count the number of total steps of a machine moving between different location.For actual positon of the machine , i...
2,217
Good day to all, Right now, i try make improvement to add one external length counter to my machine. I want when the machine running in Manual...
2,065
