Omron Zen Counter Program
zenml
Nov 2017
Eire
Hello all, new on here, and relatively new to plc programming.
I am trying to write a program which counts as it receives a cycle end input, and after a set number of cycles turns on an output for a set time, then the out put turns off and the count resets to zero and does this cycle again.
This is what i have,
Input I0 - Cycle end
Counter C0
Output Q0
Pretty basic I know, but i cannot turn off this output after a set time, or reset the counter, i spent a good while trying to figure it out
Would be grateful for any advice help
Mick
Correct me if I'm wrong . . .
But I believe you need the counter to count the inputs . . .
A timer which the counter triggers when the count is reached . . .
An output which the timer turns on when it starts . . .
And then the timer resets the counter and itself when it finishes. (Turning off the output.)
Poet.
A simple task but beyond me. How do I set a counter in a ZEN controller to decrement? I'm using the Zen Support Software and the manual clearly...
19
6,190
Hi there. I'm stuck trying to loop three outputs on a Omron Zen controller. Basically, i need to have the following: M1->M2->M3->M1->M2 etc...
6,248
I am having problems with a program I am trying to write. I am not very familiar with the ZEN. I want to; 1 Start a motor 2 Count its revolutions...
4,913
I am new to programming and have struggled with setting up a counter. I want to start a small motor driving a wheel. A prox switch is set up to...
2,867
I am very new so I will try to give as much information as possible. I cannot get a Prolific PL-2303TA USB to RS232 to connect to an Omron ZEN...
1,593
