Omron Zen Counter
RDLawrence01
Jun 2010
Indiana
I am having problems with a program I am trying to write. I am not very familiar with the ZEN. I want to;
1 Start a motor
2 Count its revolutions using a prox
3 Have a door safety interlock switch
4 Shut the motor off when a count is reached
5 Reset the system until started again.
I have attached what i have done so far. This program will not work in the similator but it will function in the relay itself but will not reset. It locks up when the count is reached.
I would appreciate any help any of you might be able to give me on this problem.
PS My IT Department will not allow ZIP files so please send your info in some other form
you need to add a line when count is complete reset the counter using the reset function designation c1 when you add counter look for the reset (you have to add as an output to get the reset option insert add coil reset while your mouse is positioned in the output of a rung
Thanks for your help, I know I appear stupid, but I do not understand what you are telling me to do. Can you please send a small sketch or add to my PDF file. I really appreciate it. This ZEN has got me totally stumped.
Your original example looked better I think, then you had the counter reset in place.
Really, man they must be tough! Is there no way you can access the site from a non-work internet connection? Then you can download the file I gave you in a previous thread.
Again, really? I thought that the simulate was the same, you must not be doing something in simulation mode. Have you put the PLC into RUN mode?
Sorry I am still being told it is corrupt. I appologize for the problem but if you could send it in any other form i would greatly appreciate it.
Sorry about this. I must of got confused.
Try this file instead, it is the .ZEN file zipped, so you will need to extract to somewhere....
Hello all, new on here, and relatively new to plc programming. I am trying to write a program which counts as it receives a cycle end input, and...
1,902
A simple task but beyond me. How do I set a counter in a ZEN controller to decrement? I'm using the Zen Support Software and the manual clearly...
19
6,194
Hi there. I'm stuck trying to loop three outputs on a Omron Zen controller. Basically, i need to have the following: M1->M2->M3->M1->M2 etc...
6,251
I am new to programming and have struggled with setting up a counter. I want to start a small motor driving a wheel. A prox switch is set up to...
2,868
I am very new so I will try to give as much information as possible. I cannot get a Prolific PL-2303TA USB to RS232 to connect to an Omron ZEN...
1,596
