Omron ZEN Counter
RDLawrence01
Jun 2010
Indiana
I am new to programming and have struggled with setting up a counter. I want to start a small motor driving a wheel. A prox switch is set up to "see" the wheel once every revolution. I want the ability to set the number of required revolutions and have the motor stop when the that number is reached.
Any help would be greatly appreciated
What have you done already? What IO do you have?
If you post what you have done, then someone can help/point out etc.
We could all whip up something that would work, but all depends on what you have done, and you have to understand it too!!
That looks like it will work, but there is no motor control.
I have attached an example of how I would do it. You will need to rename the file type to .ZEN from .ZIP (site does not allow for .ZEN type files.)
Hello all, new on here, and relatively new to plc programming. I am trying to write a program which counts as it receives a cycle end input, and...
1,902
A simple task but beyond me. How do I set a counter in a ZEN controller to decrement? I'm using the Zen Support Software and the manual clearly...
19
6,194
Hi there. I'm stuck trying to loop three outputs on a Omron Zen controller. Basically, i need to have the following: M1->M2->M3->M1->M2 etc...
6,250
I am having problems with a program I am trying to write. I am not very familiar with the ZEN. I want to; 1 Start a motor 2 Count its revolutions...
4,913
I am very new so I will try to give as much information as possible. I cannot get a Prolific PL-2303TA USB to RS232 to connect to an Omron ZEN...
1,596
