hey
Uncheck prevent overwriting done and buffer message to 1, zero is not possible to set. It's not better after this change.
I will give a little explanation of what we are doing with this CP341:
- We are reading a realtime length measurement of a carpet production line. Setting the length to zero is with a key on a multipanel. So then we use the send block once to reset. We want to receive as realtime as possible for the length, no waits..
s7xp.com said:Hardware configuration > CP settings
Uncheck "prevent overwriting" and set "buffer message size" to 0.
ASCII comms: Send -> Receive -> Send. In case "no answer", retry.
No message buffer needed.
May be it is possible to use 3 wire RS232 instead of 5 wire?
