CP5512 - Network Parameter Configuration Issues
samliu11
Nov 2006
Perth
Hi All,
I need some help here, I'm trying to set up this CP5512 adapter to communicate with the Siemens PLC, all I left is to set up the "transmission rate".
Does anyone know why this doesn't allow me to do that?
I got the full version of the program and stuff, and it works on my other computer.
If I can get any feedbacks would be really good,
Cheers,
Sam
(Attached is a picture of the issues)
This one I can configure
This one I cannot configure
Hello samliu11.
It does look weird. I havent had the same situation like you, so I am just throwing in some guesses.
Maybe you are allready online with STEP7, and thus the card is locked.
Maybe you have a Simatic PC Station configured on the PC, and it has the CP5512 assigned so that it locks the card. Is there an icon in the taskbar that looks like a small PC ? If there is, open it up and check if the CP5512 card is one of the configured components.
Thanks, I believe it might be the license or the CD not having the full version. Because I reinstalled it with another disc and it works fine.
So what I did was change the transmission rate with the disc that works and then removed the program and reinstall it with the old disc, now the transmission rate is stuck with the baudrate I want. Though I can't change it, but now I can communicate with the PLC.
It's not a perfect solution, but as long as it does the job, I'm happy.
Cheers,
Sam
That with the problem being related to a version of STEP7 sounds odd. Which software packages in which versions are you using ?
It is possible that there is a servicepack or hotfix available.
I am sure (99.9% sure) that it has nothing to do with the license though.
It sounds like you installed Simatic Net and in the "Configuration Console" it has the "access point" locked on that card. If you have, check that the "access point" is set for PG Operation and not "Configured"
I have my XP laptop that has Step 7 installed, it is the laptop I use that has a serial port & PC slot for my 5512 card. However, recently the...
2,268
We recently got a new laptop for our use and it no longer has a serial or PCMCIA slot (hooray, technological progress). We have a spiffy CP5512...
3,432
Hi, A year ago we decided to go to VMware to solve issues with different software instalments. This works great, except that the (very expensive)...
4,258
Dear all, Can anyone suggest me the way of communication between Siemens S7-313 plc to Microsoft excel can anyone let me know the price of...
2,005
Hi All, I received a new dell laptop model E5520 and I'm having problems getting the CP5512 pcmcia card to work properly. When comparing a program...
2,330
