CPC instruction from integer array to string clears string but doesn't copy
rdlackey
Dec 2011
alabama
30
Productivity3000. I have a 32 bit integer, 1d array that i need converted to a string. The string to array seems to work with the same time type of array, but the reverse does not. It clears the initial value and leaves it blank. I have increased the size of the string and also use another string i'm not currently trying to pack, but still no results. Like i said, the reverse works. What am i doing wrong?
I'm trying to dig to the source of a minor "recoverable" system fault throwing a fault light on a machine that has been confusing my operator...
89
101
Does this instruction calculate values during a single scan, or does it require number of scans based on element count in the array? For Example...
116
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
275
Hello all, I am currently trying to establish a message instruction to pass data from a 1756-L73 to a 1756-L71. My communication path from the...
365
