CPI relay logic editor, uses Genius
Well, it appears to be DOS based.
The splash screen has a date range of 1986-1995.
The instruction set is RLL, with some throw-back to PLC-2 (GET, PUT) in its own instructions.
Davenport, IOWA is mentioned as an address.
I have read through many of the post in this forum with the keyword "SCPI". I would like find out is it possible to have two way communication...
1,090
Hello all: i begin to write a OPC driver for controllogix.I find that the RSLinx read data by the tag name which i defined in PLC,not by...
4,534
Hi, I am using AB 5069-L306ERS2 CPU. My system should achieve SIL-2. I have safety door switches connected to AB 5069-IB8S module, and I want to...
115
Hello, I need assistance in making a Relay operation that follows the given parameters: -if S1 is switched and S2 is at off, the Lamp 1 will be...
116
