CPT Prob
PLCgen
Oct 2014
Barcelona
Placed the below expression in RSlogix500 and I get an error when compiling
( ( I:2.0 - 4000)/(20000 - 4000 ) * ( 200 - 0 )+ 0
the error:
Invalid expression! Two operands in sequence!
How do I resolve this ?I changed up some stuff included more brackets and still got an error of either too many parenthesis or not enough parenthesis
Change the "divide" operand to a | (pipe) not the forward slash.
(((I:2.0-4000)|(20000-4000))*(200-0))+0
Edit: dmfrey types faster then I do.
Uh, you can simplify that a bit if those literal constants are truly literals...a few parenthesis will go away too:
(I:2.0-4000)|(20000-4000)*200
(I:2.0-4000)|16000*200
(I:2.0-4000)|160*2
Put the original formula in a rung comment if you want to simplify the expression and maintain documentation of how you got there.
the error:
Looks like you had an extra parenthesis in your equation that you didn't close?
I am using the following formula and I am getting error, Invalid Expression - too many closing parenthesis. when i copy the formula to notepad or...
159
In the CPT in rung 2, i'm having an issue where if there is any value less than 0.0115 in "verticalSpeed", "festoonPosition"'s value does not...
1,118
I have ran into something I have not seen before and wondering if any one had any ideas. The logic I'm currently troubleshooting is using a...
1,664
so I have to find the standard deviation for amperage readings at my plant. when I input the formula into the CPT instruction it is automatically...
1,855
Hello, I am having trouble with the CPT in RSLogix 500, with a ML1400. At first I had everything in one equation, it gave me the Source and...
2,030
