Cpu 1214c
moggie
Apr 2002
Devon, England.
661
I have a siemens CPU 1214C PLC and a Siemens TP900 HMI connected via Ethernet.
The HMI is only for setting up - when I disconnect the HMI the PLC error LED blinks.
Is there anyway of stopping this from happening when the HMI is Disconnected?
If the HMI is only configured for HMI functionality, I've never run into that error before.
However, it is possible for the HMI to be set up as a Profinet Device, at which point the PLC would have an error if the HMI is missing.
What errors are listed in the diagnostic buffer of the PLC?
Hi All, I am trying to communicate siemens PLC with FESTO Servo & 3 Festo make Steppers on FHPP Modbus Protocol. Sometimes, I face Modbus...
1,335
Hi All, I am looking to see if anyone has had this issue before. I have a TIA portal on site which is programmed in TIA Portal V13.0 but the...
3,540
Hello everyone! I need to connect to a DL205-1 CPU and, as far as I know, I need to use DirectSOFT 6 software for the connection. Is anyone...
66
hello s7-400h and wincc are connected to each other via Ethernet. I need help on how to do time synchronization
54
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
105
