CPU 1500 and FactoryTalk SE - OPC UA
Derred
Apr 2020
milano
Hi
I connected Cpu 1518(server OPC UA) to Hmi Factory talk se 11.0 with OPC UA, and I set Kepserver 6 (client OPC UA).
I'm able to see in Kepserver all the tags that i want to share from PLC.
For find all the tags in factory talk studio is correct do like this? >>application name>>add new server DA, or is correct to add new UA server?.
Because i'm able to find all the tags in FT (to connect to HMI buttons or display) just if i add new server DA(in Factory talk).
Thank you
Derred:
Hello. Since your CPU 1518 already has support for OPC UA server and the HMI is OPC UA Client capable, I do not believe that you need to add the new server DA to the Factory talk studio. I do not think it will do harm, it's just that it seems unnecessary in your case. For example if you had another HMI panel which is legacy and which only supports OPC DA client, in this case you would need to do what you describe. I hope I understood your requirement and that this information is useful for you.
Dear Experts, I have a question regarding the redundant S7-1500 CPU and ET200M connection. Will ET200M IOs work on a redundant S7-1500...
2,104
Hi guys I was asked a question this weekend which I don’t know the answer. I hope you can help , we had an issue with a Siemens 1500 where the...
1,504
Old job-All AB... New Job-All Siemens... The idea is to take a new S7-1500 CPU and create a "ready to swap" backup for one of my machines. Had...
2,438
Hi all experts! I'm having a bit trouble with UDP communication with a CPU 1512SP-1 PN and a Kongsberg Seatex MRU 3. The MRU is set to output...
17
5,076
Hello, I’m developing a program and i found that my simulation works very well when i use CPU 1500 but when i use 1200 and i click download. A...
1,937
