CPU 313C-2 PtP cominucation with simoreg
necyil
Nov 2004
Turkey
102
Hello All,
On the machine, CPU 313C-2 PtP connect with 2 simoreg dc master drivers.
How i see setpoints send to drivers? What mean of Ptp..Is it like ptofibus..?
On hardware configration i cant see adresses.
Pls help me..
Many thaks for helps
Nec
313C-Ptp (Ptp stands for point to point) can connect to 6RA70's, Masterdrives and Micromasters via USS. It doesnt setup like profibus and the Step 7 hardware config. The drives do have individual addresses like profibus but it uses the USS address settings. Also, USS is not as fast as profibus and you cannot do routing..etc. But for an inexpensive communication network for speed setpoints- it does work.
What is the application though?
If you need more info or a sample- post back
hi... i have an issue in s7 300 plc, while we run the machine(in idle there is no fault) , plc cpu goes in SF mode, after restart the power cycle...
137
Hi guys, I have CPU S7-300-313C ( Cat No - 6ES7-313-5BE00-0AB0) DI24/DO16 and AI5/AO2. when I am trying to configure and use the AO channel PQW...
2,575
Good day, Can you give me a link or a list of how built in i/o's have been distributed with the S7-300 CPU 313C. thanks in advance for your help
1,244
Hello, I am using step7 v5.5 and wincc flex 2008. I have created my PLC program have it working, but I am having trouble with my...
16
10,092
Dear All, I have Cpu 313C and I am working on a simple project.I need to use encoder in this project. I am using ladder. I used SFB 47 block and...
1,757
