CPU speed of Allen Bradley Controllers
Although the OP is inquiring about Allen Bradley controller CPUs with regard to their bit operation execution times, so as to compare with other brands, the thread title does suggest the question - what are the speeds of Allen Bradley controller CPUs, specifically the microprocessors themselves?
Seeing as some discussion has arisen from this topic, and for those interested, I though I'd add the following specs I have...
The MicroLogix 1000 CPU is a Allen Bradley's own Micro AB23126 chip.
The MicroLogix 1100 CPU is a RISC Freescale Coldfire MCF5282. Their package type is MAPBGA 256. 8Mhz OSC - Since this clock frequency is multiplied by PLL peripheral, MCF5282 V2 Core is working with the frequency 64Mhz(= 8Mhz * 8) internally.
Features...
ColdFire V2 core delivering 76 MIPS at 80 MHz (using Dhrystone 2.1) running from cache/RAM (max running from internal flash 66 MIPS)
Cache (KB): 2 KB I/D
Integrated peripherals
10/100 Ethernet MAC Fast Ethernet Controller (FEC)
CAN 2.0B
3 universal aynchronous receive/transmitters (UARTs) with direct memory access (DMA) capability
I²C
Queued serial peripheral interface (QSPI) with four peripheral chip selects
Eight-channel 10-bit queued analog-to-digital converter (ADC)
Four 32-bit timers with capture, compare and DMA capability
Eight 16-bit timer channels for capture, compare and pulse width modulation (PWM)
PITs: Four
The MicroLogix 1400 CPU is a RISC Freescale Coldfire MCF5275. Their package type is MAPBGA 256. 20.5632Mhz OSC - Since this clock frequency is multiplied by PLL peripheral, MCF5275 V2 Core is working with the frequency 164.5056Mhz(= 20.5632Mhz * 8) internally.
Features...
ColdFire V2 core with performance up to 159 (Dhrystone 2.1) MIPS @ 166 MHz
Enhanced multiplier-accumulator (eMAC) (32 x 32) module, hardware divide
8 KB and 16 KB configurable I-/D-cache
64 KB static random access memory (SRAM)
4-channel DMA and external DMA req/ack
DDR synchronous dynamic random access memory (SDRAM) controller
JTAG
Integrated peripherals:
Up to four pulse width modulators (PWMs)
Up to three universal asynchronous receiver/transmitters (UARTs)
Up to two 10/100 fast Ethernet controllers (Dual FEC)
Four 32-bit timers
Optional I²C
Optional USB 2.0 full-speed device
Optional four programmable interrupt timers (PITs)
Optional hardware encryption—RNG, DES, 3DES, AES, BCE, MD5, SHA-1, HMAC, hash Accelerator
Iman said:CPU speed of Allen Bradley
Ken Roach said:...MicroLogix controllers run on Freescale ColdFire chips...
Features...
CAN 2.0B
I²C
PITs: Four
Features...
JTAG
Four 32-bit timers
Optional I²C
