CPU usage Siemens softplc
Hanky
Jun 2007
Oosterwolde
Hey there professionals,
I've got a strange problem which i have already posted on another forum, but somehow is seems no-one knows how to explain it.
I am using a softPLC from Siemens (WinLC V4.1). Somehow the CPU of is suffering from peakloads. But these peakloads disappear when i ajust the settings for WinLC.
setting 1:
The setting in situation 1 is 15ms mimimum cycle time and 1 ms sleep time. So the total exucution time is 16ms. (The time needed to proces the program is approx 7ms). These were our default settings. (By setting the minimum cycle time we tried to reduce the overal CPU load, and this worked)
setting 2:
But when i ajusted the settings, sleep time 7ms and minimum cycle time 0ms, i saw a much more tranquil CPU load (see figure). But i can't explain it. The total exectuin time is now approx 14 ms, and that is even faster!!
I'm satisfied with this solution.
But i would like to be able to explain my solution, can someone?
Thanks Henk,
Philips, The Netherlands.
Hi Hanky.
I have no experience with WinLC.
But I have a few educated guesses.
I am guessing that when you set a minimum cycle time, then the WinAC proces actually stays active and uses the CPU time in the time after the program cycle has finished but the minimum cycle time has not yet finished. So this means that Windows cannot uses that time to service other processes.
With a sleep time in stead, Windows is probably free to service other processes after each program cycle.
Are you using WinAC with RTX extensions ?
I think that a CPU usage of 69% is a bit high for Windows anyway.
What kind of CPU does the PC have ?
JesperMP said:
Hi Hanky.
That sounds logical, and could very well be the couse.
I'm not sure if we're using RTX extensions, what are they?
The PC has a P4 2GHz processor
Thx Henk
For example 6ES7671-0CC03-0YA0 should be "WinAC Basis" and 6ES7671-0RC05-0YA0 should be "WinAC RTX".
WinAC basis is "soft" real time ("only" a normal windows service), and WinAC RTX is "hard" real time (special low level realtime core running in parallel with windows).
Sales blah:
"SIMATIC WinAC RTX offers hard real-time and high performance. The optimized runtime system supports the processing of extensive and demanding PC applications in parallel with the control task. "
"SIMATIC WinAC RTX comprises the following components:
  • Windows Logic Controller (WinLC RTX).
  • SIMATIC NET OPC server.
  • Real-time drivers for PROFIBUS-CPs
  • Ardence RTX real-time core for guaranteeing real time and deterministics. "
Sales blah:
Hello JesperMP
It does have
But i'm in doubt. In Windows there is an exacutable called S7wlcvmx.exe. This program runs the PLC software. Maybe this helpes?
Gr Henk.
I have a machine that has 12 components on profinet. Occasionally, I lose a profinet node and then it comes back after a little while. I have a...
2,228
Hi all I am having problem with a L75 CPU which running 100 % CPU Usage. It doesn't have any Continuous Task and 50% of the CPU is taking by...
1,770
I would like to Read the CPU Usage % information like the Task Monitor tool provides from one ControlLogix to another via a CIP Message. Comms...
5,977
Hello, I am trying to perform the new Rockwell PlantPAx Verification checklist thing. If execution time is not varying on my tasks, but the CPU...
2,612
I have a pressing machine that is run by an AB PLC (V19.15) that uses a Delta RMC to control the motion of the press. We have been having...
2,942
