cpu313c
marti
Feb 2013
malaysia
I have cpu313c but in cpu I have no conter,DI8*DC24V,AI5/AO2*12bit,DI16/DO16*DC24V with firmware v2.0.8.By the way I also have done hardware update but no result.
The provided CPU nr does have an onboard counter. 3 actually.
In the HardwareConfig it is part of the CPU.
2. CPU
2.2 Digital IO
2.3 Analog IO
2.4 Counter
Double click on Counter to configure it.
The image of the terminals in the 313C CPU is wrong.
There are 40 terminals also in the left-most terminal block.
Also, both terminal blocks images are wrong. The terminals are not marked 0-7, 0-7, 0-7, 0-7, but 1-40.
Dear experts, I have the following setup: CPU-313C (6ES7313-5BF03-0AB0 V2.6) + CP343-1 (6GK7343-1EX30-0XE0 V2.0) communicating with Siemens PC...
2,706
how i configure mpi communication between etop20c HMI and 313c CPU
1,198
I am using a Siemens CPU313C-2DP to communicate to a network of Control Techniques UnidriveSP drives by way of a SM-Profibus module (new...
2,481
Hello, I need to make communication with a CPU313C and CP342-5 via profibus. I can't test this and now I need te now if this CPU can connect with...
1,659
Hi! here is my code in OB35 - configured to 100ms L time_min //time_min real variable L 1.666667E-3 //add 0.001667 minute each 100 ms (1min =...
1,420
