cqm1 slave ،hmi delta master
alikargar
Apr 2021
yzd
Hello, I know little English, I want to use 4 plc cqm1 as slave (modbus), and hmi delta as master. Unfortunately, I cannot establish rs485 communication.
is it possible???
Meanwhile, I use the rs232 to rs485 converter (delta ifd8520).
CQM1 and CQM1H are much different PLCs despite the similarities in part numbers.
I don't believe the CQM1 is capable of RS485 or ModBus.
For the CQM1H, you can get the CQM1H-SCB41 communication board the follow instructions in Parky's links.
If you can send ascii chars then it is possible The PMCR (I think it's called) is common to all processors, however, I think the OP will have to write the code to populate the message including the CRC. I'm sure the one I did was not the H version, we did not use 485, however, a simple 232/485 converter should work.
Hi! Has someone a pinout and/or wiring diagram for an old CQM1-CIF02 cable? Thanks!
1,897
Hi; I have a DUPONT brand machine having OMRON PLC CQM1-CPU21-E. I have CX Programmer installed in my Laptop having W1indow10. I want to go...
3,602
Dear All, Does anybody knows Omron CQM1 0ch Module details?? or manual i try to search but cant find manual or complete order code if this...
2,362
Hi everyone, I need to upload 2 Omron PLC programs from those PLC's: CQM1 CPU21 and CJ1M CPU22. On my laptop I have just USB ports. I have...
2,970
Hi, I've been asked what is involved to upgrade and old CQM1-21 Omron PLC to a CJ2M. I have the old file with an extension of .cdm and searches...
1,579
