dondon_alba
OP
did you check both motors winding?
Both motor windings are having an infinite reading and healthy.
Even me I was amazed with the setup. We have two stacker cranes working on the same setup (2 motors, 1 VFD & sensorless vector) working smoothly. There is an encoder on one motor. Another thing the (Parameter 80 Feedback Select) is also “ENCODER” not OPEN LOOP.
How does the VFD know "which sensorless signal" (very loosely phrased) to believe? I really don’t know.
We sum up the two motors (total power, amps,) and entered & do the parameterization.
I think I would give some thought to driving each motor with it's own VFD, add encoder to one motor and slave one VFD to the other. This is a good suggestion with a slim chance to be done since this setup is working for seven years, until the problem mentioned came.
Thanks, Don
Here is one way test what Dan is talking about safely. Have a switch or another contactor to release the brakes, this way you have better control over the testing.That goes over to mechanical.
You mentioned problems with electo mechanical brake. FOR SURE I would get them fixed before I spent one minute looking at anything else.
FOR TEST PURPOSE ONLY
Disconnect the brake electrically and have mechanic back off the adjustment for the brake to ensure NO drag - test it in this configuration and see if improvement. Leave lots of room for coasting - you have NO brakes
Yes, a single drive running two 20hp motors, one on each end of the bridge, that are not mechanically connected.
Will have another look at crabbing. One of the early findings was that one of the brakes was not functioning, with the thought that at stop, that end of the bridge may roll out of square with respect to the rails and the jerking was a result of getting lined back up true again.
Hadn't thought of actually measuring the individual motor torque. Will have to do some figuring on how to do this, while staying within the plant safety rules.
Thanks for the ideas!
Are you running with any slip compensation? If so, you may want to try and turn it off.
Does anyone know why "they" don't use synchronous motors on these things? Keith
