Crimson 3 syntax question
mvaughan
Sep 2007
South West Michigan
62
OK, I am feeling a little stupid. I can't figure out the syntax for an (IF, OR) statement in Crimson 3. Maybe because It's Sunday and I am still working on this?o_O
I have 8 Boolean var. and if any are true I need to return a true to a 9th flag.
Any help would be appreciated!
Regards
The OR operator in Crimson is a double pipe (||). Two methods to accomplish what you want:
Code:
if(Var1 || Var2 || Var3 ...) Flag9:=true;
else Flag9:=false;
Code:
Flag9 := Var1 || Var2 || Var3 ... ;
The second method can be simplified even further. Just set the Source of the Flag9 tag to "General" and use the expression "Var1 || Var2 || Var3 ..."
Hello all, first time poster here! I have a toggle button "REVERSE_ENABLE_BUTTON" on our HMI's that disables our "bad product rejections" by...
2,183
Hi, I have a Red Lion E3 io counting output from weld cells, connected to a PTV station for the visuals. Our number of weld cells is set to...
1,566
Can anyone help me with proper code syntax for setting or stuffing the value of one tag into another (PLC = HMI tag). I have FactoryTalk SE...
2,697
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
147
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
289
