Edmhydraulics
Hi everybody, I am in a bit of a pickle, I recently a Crouzet EM4 PLC off DigiKey, I know I probably should not have done that, but I needed something fast, like overnight and Digikey is good for that. The EM4 is a pretty sharp little plc, lots of analog inputs, High speed inputs, and the programming software is dead simple.
My plan was to connect the PLC to a Maple Systems HMI using Modbus TPC/IP over ethernet, but no matter what I do I cant get a connection. The PLC can only be set up as a slave in a modbus system.
I have tried everything to get them to talk, it looks like they are connected but there is no data being transmitted between them. The ip of the PLC is 192.168.68.12 and the HMI is 192.168.68.5 and the subnet is 255.255.0.0.
Anybody here have experience with Crouzet??
Thanks.
Thanks.
