ctc machine shop's profibus conversion to abdh
chue.lee
Sep 2008
California
Well, I'm trying to change the profibus to abdh( data highway) on a ctc hmi screen. I'm using machineshop software. Their tutorials or examples are given as
ABDH\25$B3:3,14
DRIVER NAME ABDH
PLC STATION
NUMBER 25
MEMORY TYPE B FOR BINARY
FILE NUMBER 3
ELEMENT NUMBER 3
BIT NUMBER 14
Okay so mine on the hmi programing was abdh\2$B3:21,6. It doesn't work.
the $ is the delimiter between the station number and the memory type. This is the way of doing it for the slc 500 and micrologix series. I have a slc 5/03 that's already hooked up to the program but then after I download the program in the hmi and try on a bit, it doesn't turn on in the program itself. So I did a new program with just those bits and another set of bit for the output and it didn't turn on also. So I know it's just the stuff I did on the Programming for the screen. I'm not sure if the tag name has anything to do with it. It's like @i:6.10,0 and my address reference for it is abdh\2$b3:20,0.
Now my question is, how do I get it to work with the program. any help would be appreciated.
If your communication settings are correct try this. Change abdh\2$B3:21,6 to this abdh\2$B3,342.
Did you configure the ABDH driver in the Interact Application Manager - particularly the COM Port and PLC Stations tabs? Similar question about the SLC-5/03 Channel 0 settings.
As for the tag name, I have never called tags by names like that. However, you can reference the input points without a tag. For example, you could read I:4/0 by using ABDH\2$I:4,0 in Interact.
Hi everyone, I got a Parker HMI, CTC PA2. I tried to download program to it but it froze in the process and could not finalize. Now, when I try to...
62
Anyone ever heard of CTC PLC's? Not even sure if they're around anymore, I think they source out of Hopkinton MA but I could be wrong. They seem...
1,668
Hi, I have tried uploading the program from an old Quick Panel 2 using Proficy ME 9.0 and Quick Designer 3.7. I can get the program to upload...
1,473
Hi, I have an old unit HMI with model PA10T-133 (PA Powerstations series). 1. I just have an inquiry whether which particular software to use...
1,886
I am taking over a CTC Interact project. All I have to start with is the LRP file. I do not know what version it was written in. It was done...
1,869
