CTI 2572 Ethernet NIC
RoTaTech
May 2003
Cobourg, ON, Canada
418
We have six NICs for Siemens 505 chassis at our place, and four are acting normally.
Two are not able to complete set-up. I have tried both the CTI Diag utility for Windows, and the 2572IPSET for DOS utility; they have similar but not identical results.
I am trying to set the cards to IP address 192.168.3.7x, and a router of 192.168.3.1, and a subnet mask of 255.255.255.0, and (default)port 1505 .
The bizarre part is that I can change the IP, router, port at will, and the change takes effect. However both cards will always reset their net masks.
The card does a READ to show me the present values, then I choose to WRITE, and it does a confirming READ. I will only show the netmask result here, as all other fields work fine.
Card1: using 2572IPSET
trial 1 WRITE 255.255.255.0 READ 10.53.0.22
trial 2 WRITE 255.255.255.0 READ 10.65.0.22
try IPSET /I (display only) reads 10.64.0.22
trial 3 using CTIDiag WRITE 255.255.255.0 READ 115.221.233.0
Card 2: using either
all trials WRITE 255.255.255.0 READ 10.20.0.22
I have also tried setting the mask to 0.0.0.0; results are same.
Yes I have tried with and without power cycle between the Write and another Read - no difference. Please recall that I have successfully configured four other cards, so I know what they should be doing.
The EEPROMS in the cards are both dated 1995; one is version 2.0, the other version 4.5. CTI tech support has suggested that the EEPROMS are 'fried', however this seems like a mighty selective failure for both cards to have almost identical problems. As well, the difference between reading the one with CTIDiag versus 2572IPSET is also exceeding strange.
I tried swapping the EEPROMS in from one of the newer cards, but I could not even go on-line with it then.
CTI want to sell me new rev. B cards to solve the problem.
Ideas, anyone?
No, Ken, they are in my test bench rack.
I know that setting the address can be done two ways: the utility or through logic. I thought it more expedient to use the utility. There is no logic overwrite - they have unique addresses the program in nothing but a single END statement.
I've not tried the logic method, but I shall.
Also, with the age of those cards, If there was a previous set of logic that wrote to the EEPROM it could conceivably have damaged specific portions of the flash.
Hi All, We've got a CTi based system with 4 racks. The CPU is in the 1st rack and there are 3 remote racks numbered 1, 2, and 3. We are...
4,721
Hello to everyone. In the part of the malting plant where I work we use CTI plc,s to control the malting proces. In all the other plants Siemens...
1,975
I'm having trouble programming a PID loop in 505 workshop. Are there any examples out there of how to program this, or how it even works? I got a...
1,495
Looking to see if anyone has been sucessfull in getting a Siemens plc, either s7-300/1200 or even 1500 to control the brooks automation cti...
1,694
I am in need of some help. Currently have a CTI cryogenics pump with an onboard and keypad. Management would like to allow our customers to...
4,364
