CTU PRE variable?
Jul 2017
Michigan
21
Hi Guys,
What the quick and dirty way to load a PRE value to a counter in a ML1200 from a C-More HMI?
Having trouble using the HMI to reset a batch counter.
Thanks in advance!
I got it figured out.
Momentary button on the HMI for a bit to trigger the RES command.
I thought I could just have a button with the RES command in it, but had to do it on the PLC side toggling a bit
Hi, I need to use my CV value from my CTU. if CV = 1 : Red light turns ons if CV = 2 : Green light turns ons, but red goed out if CV = 3 ...
293
Hi, I am confused regarding TIA portal and counters. I use CTU. I wish to have one counter counting 0-10. When it reaches 10 is shall increase...
23
3,193
I haven't come across this before. I am trying to understand why the counter doesn't reset to 0, when the .dn is true? It immediately puts a 1 in...
18
4,605
This counter is counting when bits_from_traypacker is true (messaging from other machine, this is the servo cycle). After counting 3 it should...
3,288
For a week now, my coworker and I have been troubleshooting a machine which has been displaying some crazy behavior. HMI values were changing on...
19
4,268
