cuvc card change
Amar88
Jul 2014
India
If i can cuvc card in siemens vfd ... which parameters i have to re-enter and how i can enter the parameters pls tell me i need it very urgent.
do i have to change the board related parameter ??? i read in some manual but i am confused. in manual they written that change the p060 parameter by selecting value 4. how i can do it pls suggest me i am new and i dont know how to enter the parameter value
Use the Drivemonitor software from Siemens to backup the parameters of the old CUVC card and then restore them to the new CUVC card. If you don't do this, you will have to re-commission the drive from scratch. If you don't understand how to make settings in the drive then find someone that does.
You may need to set the MLFB number in the CUVC to tell it what type of drive it is fitted to.
You should be aware that the CUVC drives are now very old and that different versions of firmware may pruduce different results in drive behaviour; One version existed where some gains were multiplied by 10 and onather version I came accross doubled or haved some setpoints and feedbacks.
My best advice is to contact Siemens for their advice.
Nick
How can I download the paramters for a new cuvc card through a brofibus network mostafa65
3,569
i have to do comissning of ac drive ( master drive siemens) i have one programable joystick means its user define divice i know...
2,909
Hi, I work with these Siemens Simovert Masterdrives VC, I was wondering if anybody could help me with documentation and files on how the download...
3,219
Hi all Most of our drives are Siemens masterdrives with rectifier and invereter with CUVC card. One of the invereters in other plant is using...
4,940
Omron AD081-V1 Analog Input Card Offset & Gain Adjustment Entering Adjustment Mode 1. Set the input card in adjustment mode (Turn ON Dip SW No-1)...
100
