CX One message - don't know how to fix
gfr
Aug 2009
Vancouver
This message is popping up when I load a CX project. I thought I installed the updates but I am not certain. Auto updates is not working so I'm doing it the hard way.
Any idea of how to get this file loaded. I am getting this message. (CX Programmer 6.1) but can't find a menu item as mentioned.
CPS_CP1H-X40DT1-D_Ver1_1.xml
Install the CPS in the following procedure.
Execute the [File - Install CPS] menu in the IO table and restart the support software after completing the installation.
Your help much appreciated.
David
David,
I have attached the CPS file you are looking for.
You will need to unzip the file.
You will need to put the file at the following location:
C:\Program Files\Common Files\Omron\Profiles\CPSFiles
This is the default location, if you changed things at installation you will need to adjust.
FYI, you should probably talk to your Omron distributor about upgrading your CX-One. CX-Programmer is up to version 8.2.
Hope this will help.
Thank you very much for the CPS file. I have copied the .XML file to the Program files\common\omron\Profiles\CPS folder but still get the same message.
CX-Integrator TOOLS\CPS\INSTALL said it was already installed and asked if I wanted to update. Upadate returned a "Failed to install CPS_CP1H-40DT1-D_Ver1_1.xml
I'm not sure if the .DTD file needs to be updated or not but still no joy.
Hi All, I'm just trying to understand the reason behind something I recently experienced. Background: The system contains 4 CompactLogix...
128
Developed a FactoryTalk SE program in English (Canada), finally setup the alarms and the message is reading "Message not defined for language...
49
hi everyone, i have problem regarding Audit in FTV ver 12,In audit message "service disruption:<HMI server name>:<SERVICE NAME>" message logged,i...
58
Is there a way to add a local message display to Studio 5000 View Designer? If its there, I’m not finding it. I have used them in older versions...
434
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
152
