Cx-programmer - changing timx sv using a variable
Adam_White91
Nov 2013
NSW
Just trying to use a variable to change the SV on a timx timer. Im using a hmi to input a minute value then I times that by 600 to get the right value for my timer. The reason for using a timx timer is because I need a timer capable of counting over 999.9S. I can do the multiply and change the SV fine with a BCD type timer and BCD type multiply instruction *B. But when i use the *U instruction with binary numbers it spits out weird numbers can someone please help. Ive attached two screenshots of my my programs. One is a example of my BCD multiply and timer which works OK but unfortunately need a longer range then 999.9S the other screenshot is my binary multiply which does not work.
PLC - CP1L-EM
CX-PROGRAMMER
Yeah sorry I did change it to decimal it all works sorry for the inconvenience should of posted earlier that I found the problem. Just one of them days...
Hello, I am trying to make a sequence program by using MOV function to change the value of a register. So far I have always used SET and RSET for...
2,207
bonjour je souhaiterais savoir si c'est possible de faire communiquer Cx-programmer ( logiciel de programmation des automates Omron ) avec...
157
Dear All, I need a sample PLC program to count the output pulse of a mass flow meter so that a specific amount of mass (for example 100gm)can be...
158
I need a good website or tutorial to learn plc programming Thank you
511
Hello ! I am trying to use an omron cj2m-cpu33 with a CP1W-CIF01 plug in serial connector to talk to a zebra ZT610 printer. I am getting the data...
383
