cx-programmer&labview
Merlaud
Jun 2022
Douala
bonjour
je souhaiterais savoir si c'est possible de faire communiquer Cx-programmer ( logiciel de programmation des automates Omron ) avec LabVIEW sur le même PC à travers le même port COM (9600; 7;2;E) avec Host Link comme protocole de communication .
merci por la comprehension
bonjour
I would like to know if it is possible to make Cx-programmer (Omron PLC programming software) communicate with LabVIEW on the same PC through the same COM port (9600; 7; 2; E) with Host Link as the communication protocol.
Thank you for the understanding
If I understand correctly, you want to communicate with the PLC via Labview and CX Programmer on an RS232C COM port?
This will not be possible. RS232C is 1 to 1 communication. Likely what you encountered was "COM port busy" or "COM port not available". This is normal when the COM port is currently in use.
d
ok I will use virtual ports
Dear All, I need a sample PLC program to count the output pulse of a mass flow meter so that a specific amount of mass (for example 100gm)can be...
158
I need a good website or tutorial to learn plc programming Thank you
512
Hello ! I am trying to use an omron cj2m-cpu33 with a CP1W-CIF01 plug in serial connector to talk to a zebra ZT610 printer. I am getting the data...
385
Dear all, First of all thanks for letting me join this forum. I just need some help in one of my programming exercises. Being a beginner...
615
Hello everyone, A client has asked us to change a bit of logic on his PLC. Our job is to put a new transmitter, reading it with Modbus RTU. He...
393
