Cx programmer pid and tpo program help
First
Sep 2018
N
Hello
Can someone please help me make a program to cj1m omron plc.
Hardware: cj1m cpu 12
ad041 v1, id211, oc211,od212
I will use the plc to my homebrew setup. I have a solid-state relay which I want to heat water with. I think I need a program with pidat and a tpo instruction.
Earlier i have just used pid functionsblock, bit it did not work with the old plc. With omrons pid instruction theres some parameters i need to set. I dont understand how.
I guess this is an easy job for you guysšŸ˜€
First,
Welcome to the forum.
Please see the attached files. This information is from the W340 Instruction Reference manual for the CJ/CS series plc's.
This should provide the information you are looking for.
I would like to compile a list of all the CX-Programmer PID Best Practices If there is some clever way you have figured out to do something and...
676
Hello guys I have a project in which I have to control the water level of a tank using Omron. I need to get the pressure transmitter value in...
4,359
bonjour je souhaiterais savoir si c'est possible de faire communiquer Cx-programmer ( logiciel de programmation des automates Omron ) avec...
157
Dear All, I need a sample PLC program to count the output pulse of a mass flow meter so that a specific amount of mass (for example 100gm)can be...
158
I need a good website or tutorial to learn plc programming Thank you
511
