cx programmer problem
chandrapaul
Mar 2016
bangladesh
119
hi,
i installed the cx programmer trial version with some error messages. after completion of the installation when i am trying to open the software then its showing attached error.
how to solve the problem. please help me...
thanks
If you uninstall it you must use the uninstall progam - Windows will not do it properly.
a) Probably you will need to download the CX Programmer from the Omron webpage because your current installation file seems to be corrupted.
b) Restore your PC to a moment previous to your first try with CX Programmer. Since the first installation had some problems, it's possible that there're wrong entries in the Windows Register.
c) Also, check the compatibility of your Windows.
Use the uninstall program that is in the Omron folder and re-install. It is compatible with Windows 7, 8 & 10 either 32 or 64 bit. You could also check at myomron.com - you have to join but it costs nothing.
I am stuck on what is likely a misunderstanding of how Omron handles data versus Rockwell. I need to scale an analog input to monitor the...
1,540
Hi there ,i'm using a CQM01 PLC for my project. I was just testing the input and output of my PLC with a very basic program with only one contact...
2,516
In the hand position: Pumps 1 and 2 are controlled and alternated by the hand selector switch. When Hand position is first selected, pump 1...
3,602
Hi there, PLC in question: 240VAC Omron CP1E-NA20DR-A Features: 12 inputs – 2 of which analogue, 8 outputs – 1 of which analogue My question is...
19
18,996
Dear All my company purchased a full version of CX-One V 4. from there i got Cx-programmer v 9.1 and also an update for the CJ2M as they bought...
6,743
