Cylic and acyclic communication.
tomizzo11
Jul 2013
Michigan
49
So I've already searched if there was a question like this posted before, but I wasn't able to find the answer I liked.
I've been working with some PLCs and variable frequency drives lately and thought it was about time I finally found out what cyclic and non-cyclic communication is.
So correct me if I'm wrong, but when I think of cyclic data, I think of data that is continuously being updated and is able to be sent/sampled to other devices. With relation to what I'm doing, I'm thinking that the variable frequency drive is able to update information such as speed and frequency that can be sampled/read from a PLC. This is what I would consider cyclic communication, something that is always updating a certain type of information that can be sent as data.
So I might be completely wrong with this assumption, and that leaves me with the question of what exactly would be considered non-cyclic or acyclic communication.
Any help?
You are pretty close. As the name implies, cyclic communication happens every cycle, scan, time slice... whatever you mayt call it. It is the data exchange that occurs at the regular pre-determined time intervals, has higher priority and is being used to transmit the most time-critical data (in your example, the VFD's speed command/actual speed feedback).
Anything else that can wait, so to speak, is transferred via non-cyclic communication. For instance, the PLC program needs to update a VFD's parameter value. In that case, the PLC sends the request and expects some acknowledgement in return; this happens only once and not every cycle continuously.
Hello. Is there a way of "asking" a CPU (S7-300/400) about how many acyclic jobs that are active? As I understand, there is a restriction of 8...
2,446
I am having an issue with Acyclic Reading/ Writing of Data! It did appear to be working however I have realised the data is going to the instance...
1,459
Hi all, I could use a little bit of help. I am currently developing a standard block for a Rotork valve which is to communicate to a S7-300 PLC...
1,969
All I need some help, I need to read and write some data to a device on my Profibus DPV1 Network. The device in question is an Anybus Card...
5,376
HI I am new to the forum and have a burning question related to the project I am working on. Can anyone inform me how to carry out an acyclic...
1,394
