Daisy chain photo eye or sensor
eight_bools
Apr 2019
Oklahoma
71
Good Evening,
I am working on a warehouse loading dock setup with 60 docks, trying to do trailer detection with display as to which docks are currently open. I dead is to use probably an ultrasonic sensor mounted above each dock.
Is there a bus technology out there that allows for daisy chain install of sensors? I know that Allen Bradley used to have devicenet photoeyes that could be daisy chained using condulet adapters. They have been discontinued, and it is a pretty old communication method.
I do not know much about IO link, is that capable of doing what I am looking for? I attached a photo of the condulet adapters I was talking about. Any help is appreciated.
Correction, could not post a photo from my iPad, link is below
https://us.rs-online.com/product/turck/ca-2-fk-4-5/70779575/
IO has a maximum range between master and device of 20m, why not use sensors with Ethernet/IP, PROFINET, EtherCAT or similar CAT5 based interfaces that can easily span 100m, or more with the addition of a cheap switch?
Price. I've seen IO link on £100 sensors, by the time you get profinet capable sensors you'd be better off just using a couple of remote IO terminals.
Also throwing in AS-i and RS-485 into the mix. They're pretty much designed for daisy chaining.
Hi, I am looking to migrate some of our Electronic Overloads off of a Troublesome Devicenet Segment. Is there any documentation confirming the...
110
So we are running a RS485 network inside our cabinet. We have 4 rs485 devices inside. I've read that the network needs to be daisy chained (not...
2,868
Hello, I am trying to program an assembly line for two kinds of product manufacturing. This products would be manufactured in a random sequence...
2,151
Hi Everyone Im looking at networking a set of machines that can have their order swapped or even totally removed. They are all physically in...
1,754
We have some old lines that have many door and cover switches integrated as part of the estop circuit. Some of these circuits have 60+ devices...
46
12,034
