Clay B.
Sounds like grimlins
I Mov supresses voltage surges as the relay opens. It still sounds like your root cause is the relay opening.
I would confirm a voltage drop across the Relay coil itself.
Hook your meter across the relay, set your Min/Max and let the next event happen. For that relay to drop out the seal in contacts must open or something upstream has to drop the voltage.
Just keep moving upstream of this coil until the voltage drop shows itself.
You can knock a seal in contact open with vibration. The good news here is if it is a cube relay you will see some arch damage on the contacts. If you have not thrown the old realy away pop the cover off and look for this.
Don't get frustrated though. Chasing problems like this is like trying to catch smoke with a net. Just do not start jumping around, a systematic aproach will always work best.
