"Daisy-chaining" Managed Switches
BillRobinson
Oct 2006
Sydney, Nova Scotia
185
Just wondering if this is a no-no.
Just as a background i'm using Allen-Bradley RSLogix 5000 over Ethernet/IP with remote IO racks and 3rd Party HMI. The switch is a Hirchmann with IGMP snooping enabled
I was doing an upgrade to an existing site last year which required an extra Ethernet connection to the thier PLC network. The existing switch had already used up all of it's ports so instead of replacing the existing switch I added a smaller switch and "jumped" the 2 switches together with a normal ethernet cable.
I was later told by a network guy that this is a bad idea.
Any thoughts?
well you want to keep an eye on the number of switches
the max number of switch hops is 4
so is you branch off of the MDF switch to the Hirchmann then just don't go to 4 Hirchmann but you might not be connecting to a plant wide network so then you can use 4 Hirchmann but don't make a loop
and it is better to use a larger switch than a bunch of switches but PLC's won't see the benefit
if it is a plant wide network then you'll want to watch how many switches have to go through for one thing to reach another
Last night I ran into three drives on the same speed control 4-20. I had never seen this before and thought multiple devices would cause...
3,763
Hello, Trying to figure out if I can daisy chain powerflex 525's without using RS-485 cables and just using cat5 to the ethernet ports. Each...
4,989
Hi all, Wondering what is the preferred method for running power around the panel. For example when building a panel if you have 24VDC from a...
22
8,049
I have three shipping lines with a bagger, printer, palletizer and stretch wrapper. The bagger and palletizer each have a hub. My preference is...
8,839
First, I have lots of copper networking experience, but next to no fiber experience. I bought eight unmanaged network switches (8 x copper...
1,950
