danfoss drive replacement
akhunzada136
Feb 2014
karachi
hello dear...i am replacing master drive by danfoss drive using plc s7-400 414-2dp . while 39 drives are communicating with rhe master through profibus. when i am adding a denfoss to hardware then it builds communication with plc but some of the drives i.e master drives showing fault82 and not communicating. :cry::cry:... any idea.....
Fault - 82 CSIV parameter error
Do you have Danfoss software MCT-10? upload/download
or you can use LCP
check the Profibus node/address on parameter no:9.?
check parameters no:15 Drive information?
mostly your configuration wrong/corrupt
or you need to send back to supplier
i have attach example for reference only.
please link and check and read page 126
Operating Instructions MCT10,
http://mcliterature.danfoss.com/WebPublish/downloadPub.do?no=0
reply
thanks osmanmom for replying.
i have mct10 software and configuring through it. the fault is showing on master drive the danfoss drive i have added working . but my task is to communicate all the 39 drives .thanks for your reply. dear i will also read danfoss docx. and will check the parameters.
Hey guys. As the title suggests, I need to configure a Danfoss Aquadrive FC202 inverter, so that its logic inhibits the local command when the...
52
Hello all. I am hoping someone here has installed a Danfoss VLT Midi FC 280 and connected an encoder to it. I am just trying to make sure I select...
470
Hello everyone, I am an engineering student who took on a project to design and build a control system for an industrial coffee roaster as my...
4,515
I want to read voltage and current from a Danfoss drive FC300 with S7-300 PLC. I need help with the programming. Hardware bit has been done by OEM.
6,528
Need help. Does anybody have a running copy of Danfoss MCT 10 software running that can take a drive parameter file and print it out in PDF...
1,808
