Danfoss FC302 - Devicenet Installation
juan_monzon
Apr 2010
Belize
Hello everyone!
I have had some problems installing a new FC302 frequency drive in replacement of a Danfoss VLT5011. My biggest problem is that the devicenet network has not recognized the new drive. The software that I have been using is Devicenet Manager but that is a software I have not used and I also haven't been able to find the user manual but I have tried different things that have not worked so far. I installed the EDS file that corresponds to the FC302, I set the connection up and deleted the old device from the node that I want to use (in my case it is number 40)then I dragged the new device from the EDS list, I assigned node number 40 to it and ran a network who, but the network still doesn't recognize the new device, and I have not even gotten a question mark as it happens with RSNetworx; another thing is that I haven't found any icons or commands with which I can perform a download or an upload of a network configuration to or from the scanner, so I am not sure if I am following the right procedure to replace the device in node 40 or if I am skiping any steps. I will appreciate very much if anyone could give me any instructions on how to modify the network configuration and how to download it to the scanner with devicenet manager. Thanks in advance.
Regards,
Juan
Hello! First post here! Trying to commission a Danfoss FC302 frequency converter (with option A MCA121 EthernetIP-card) connected to ABB AC800M...
1,259
Im working with Danfoss fc302, i got a simple problem inyet icant fixed it, can you help me, we had several drive in our project, to be able...
2,015
Hello, At the company where I'm working for they have standard FB's for controlling FC302 drives. When we do not have a signal to the PLC from...
2,032
Hi, I have a small danfoss FC302 VSD giving a Mech brake low [A63] alarm once or twice a day for some reason. There is no brake and the only I/O...
7,382
Hello, I'm using a Danfoss drive FC302 connect via profidrive to a Siemens PLC 315. My problem is how can I read from the drive a current upper...
2,191
