Danfoss FC302 - Read current 32Bit
davidevet1983
Oct 2014
Padova
Hello,
I'm using a Danfoss drive FC302 connect via profidrive to a Siemens PLC 315.
My problem is how can I read from the drive a current upper than 327 A?
How can I setting the PCD drive for 32bit motor current?
Thanks!!!
Isn't this automatically scaled when you use a larger machine?
Also, contact Danfoss support, they are very knowledgeable
Hi David!
You should be able to read up to 675 A in one PCD channel.
If you need more you map the motor current in 2 PCD channels, as long as you keep them in Par. 9-16.2 and 9-16.3 OR 9-16.4 and 9-16.5 OR 9-16.6 and 9-16.7 OR 9-16.8 and 9-16.9 it will automatically use the 32 bit for your current instead of the 16 bit usually used.
Best regards,
Michal_dk
Hello! First post here! Trying to commission a Danfoss FC302 frequency converter (with option A MCA121 EthernetIP-card) connected to ABB AC800M...
1,254
Im working with Danfoss fc302, i got a simple problem inyet icant fixed it, can you help me, we had several drive in our project, to be able...
2,011
Hello, At the company where I'm working for they have standard FB's for controlling FC302 drives. When we do not have a signal to the PLC from...
2,026
Hi, I have a small danfoss FC302 VSD giving a Mech brake low [A63] alarm once or twice a day for some reason. There is no brake and the only I/O...
7,372
Dear All I want to use Danfoss fc 302 Preset Refrence .can anybody guide me on this ...thanks in advance
1,898
