Danfoss FC302
Preset reference is used when setting a predefined reference for the drive. The FC 302 has 8 preset reference points (Par. 3-10.0....3-10.7).
The Preset references are selectable from digital inputs, but you need to set up the inputs you want to use (Par. 5-1x). 3 bits a possible (Preset ref bit 0, 1 and 2).
If you set Terminal 18, 19 and 29 to those respectively this is what you'll get:
T18 T19 T29
0 0 0 = Preset Reference 0 (Par. 3-10.0)
1 0 0 = Preset Reference 1 (Par. 3-10.1)
0 1 0 = Preset Reference 2 (Par. 3-10.2)
1 1 0 = Preset Reference 3 (Par. 3-10.3)
0 0 1 = Preset Reference 4 (Par. 3-10.4)
And so on (sory the layout of the forum does not permit me to space the way I wanted to)
If you are using a bus system, I'd not bother with preset references but rather make that in my PLC and just use the reference word to send it to the drive.
Hello! First post here! Trying to commission a Danfoss FC302 frequency converter (with option A MCA121 EthernetIP-card) connected to ABB AC800M...
1,253
Im working with Danfoss fc302, i got a simple problem inyet icant fixed it, can you help me, we had several drive in our project, to be able...
2,011
Hello, At the company where I'm working for they have standard FB's for controlling FC302 drives. When we do not have a signal to the PLC from...
2,024
Hi, I have a small danfoss FC302 VSD giving a Mech brake low [A63] alarm once or twice a day for some reason. There is no brake and the only I/O...
7,372
Hello, I'm using a Danfoss drive FC302 connect via profidrive to a Siemens PLC 315. My problem is how can I read from the drive a current upper...
2,186
