Data Connection between GEFanuc 90-30 and Mitsubishi FX Series
If you have TopServer communicating to Wonderware, you could buy TopServer Driver for GE also and move data through Wonderware scripts....like "While Running"...
Cheers Nathan.
I appreciate I can control via WW, just try to avoid it if possible, because if WW was to go down we would lose the controls and stop the plant. We don’t do any controls that way, as WW isn’t constantly monitored, sadly.
But thanks for the suggestion.
Cheers Nathan.
Understood... that is why I usually have my Intouch apps not require a function from Wonderware to continue a plc operation. It just depends on how important data is and what happens if InTouch crashes.
I would suggest again to use Modbus TCP/IP. It is easy and quite reliable and cost effective. PLC to PLC communication.
Yes... There is another option. GE 374 CPU will talk Modbus TCP (with correct firmware), you will have to verify the Mitsubishi.
Tips for Mitsubishi as Modbus TCP/IP Client:
1. Download FX Configurator EN
2. Check example in the attachment from the time when Mitsubishi and Beijer were in love.
Note, it is example for GX IEC Developer, but the library can be used with Gx Works2 without problem.
When E300 powered off, the ethernet device tag data stayed at last know state, for example, fault bit is still Off, ready bit is still ON, status...
1,010
Hello All, I'm looking to receive data remotely from a site, and was looking to get connectivity to the site via a 3g connection. Does anyone...
2,949
Dears I wonder if I can work and navigate on my Omron HMI NT21 through pages without connecting to the PLC because it sticks/freezes on "System...
2,024
Hi everyone , Im from Portugal. I dont know if you can help or not but im little lost in this. I have a project in my hands that i need to...
3,289
Hello! I need to know if its possible to transfer data between two PLCs that are on the same ethernet network but NOT contained within the same...
3,418
