Data Highway + Breakout Adapter?
mmp
Mar 2010
Chicago
I'm quoting a system upgrade for a client who has a legacy ISA card, 1784-KTX. For the upgrade I want to replace it with a 1784U2DHP (USB Data Highway Plus). The way the ISA card interfaces with the system is through 3 screw terminals. The new USB adapter will instead have the standard DH+ connector on the end of it. A gentleman I spoke with at Rockwell recommended I get a third party adapter that will convert to three wires or a breakout, rather than pig-tailing the connector. I haven't been able to find anything with a quick search but I'm guessing someone here has used such a thing.
Any recommendations?
Awesome. That helps a bunch. Ideally if I have to pigtail it I would prefer to not have to destroy the $1500 cable, so it would be nice to find a cheap female (asuming the 1784U2DHP is male) connector to plug it into and just pigtail that connector.
If I remember, AB used to send out the 9-pin to round connector with all the PLC5's. There has got to be some available somewhere.
Hey everyone! I am trying to set up some messaging between two of our older PLC's, having difficulty getting the configuration nailed. I've made...
1,281
I seek the wisdom of the old men on the mountain. I am working with an old data highway network while upgrading from PLC 5 to 5000. In order...
3,986
Does anyone have the setup disk or drivers for sst 5136 data highway card? if so can you point me in the right direction. Thanks
1,766
We have a customer who has a PLC5/25 controller that uses interfaces to a Fischer-Provox system using a 1785-KA on the PLC5 end and a 1771-KX1 on...
1,645
I have a Data Highway Plus network for programming PLC's. I have a new machine that has a Micrologix 1200 in it and I need to see if I can add it...
3,162
