Hey everyone!
I am trying to set up some messaging between two of our older PLC's, having difficulty getting the configuration nailed.
I've made an integer table in both PLC's, and I have a MSG table in one right now. Eventually I plan to set up read/write both ways, but that should be relatively trivial once I get one direction working.
The message path is as follows:
PLC5/40E series D Rev B
Ethernet on Channel 2 (192.168.1.76)
DH Bridge (192.168.1.50)
Ride the Data Highway to a PLC5/30C Rev H, which is node 77o
In trying to set this up I've tried multiple configurations on the PLC5/40E. I tried to do a multihop configuration, as that seemed pretty intuitive to set up, but was greeted with "Ethernet Multihop is not available for this processor type".
So I am currently assuming that it'll have to be some kind of IP path, as I've done before with CLX->PLC5 messaging. Under the target device section, I've got my data table set correctly, multihop set to no, and Ethernet IP Address is where I'm stuck. I've tried several variations, such as 192.168.1.50, 1, 2 - that should be the DH Bridge, backplane, slot 2, which is the DHRIO card that has the data highway network on it. I've tried following the routing table in my RSLINX, which would give something like 192.168.1.50, 20, 2, 8, (then maybe 77?). That would be the DH Bridge, Link 20 is the backplane, slot 2 is the DHRIO card, link 8 is channel B, which is the data highway channel. I've tried including the 77 (octal node of the PLC5/30C), I've tried 63 (decimal conversion), and I've tried excluding that entirely.
Any advice would be greatly appreciated. This data highway network was put in before my time, and has zero documentation, network drawings, etc.
Thanks!
Thanks!
