Data Hwy Messaging
2003sfp
Aug 2011
Alberta
Need help getting a MSG from one data highway to another on PLC 5. One DH+ network is in one building and terminates at a desktop computer on a 1784-PKTX card.(Node 00) A separate building has the identical setup (desktop @ Node 60)and we use the business ethernet network to bridge between the two 1784-PKTX cards. At the desktop computer in either building I can open and work on any PLC on either DH+ network but I can't get a MSG block configured properly to get through from one DH+ network to the other.
RSLinx Gateway is on both desktops with the PKTX cards. I've done this using a ControlLogix Rack with two DHRIO modules but, I don't have that option here. Any ideas? ....Bob
I don't think you can do this. RSLinx Classic Gateway's major feature was application connectivity to the local DH+ drivers via TCP, but it doesn't have the network-to-network bridging features of the 1756-DHRIO or 1771-KA module.
You might accomplish this with an OPC mirror of some sort, but the principal solution is going to be the 1756-DHRIO module.
I have 4 SLC 504 plc's connected by DH+ and am passing only one word of info per PLC between them using the B60 file.I am have run out of bits to...
1,661
I have 10 A/B PLC 5's and 7 HMI's along with 3 computers on our data hwy. All the PLC's are messaging production data back to a computer that...
27
8,569
Hello everybody, I'm currently working on a project where I need to implement an IoT platform based on Microsoft Azure Cloud. Communication is...
51
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
75
63
