Data Hwy word limits
chainsaw2272
Jan 2014
joliet
I have 4 SLC 504 plc's connected by DH+ and am passing only one word of info per PLC between them using the B60 file.I am have run out of bits to pass from one of the PLC's and need more info from that location. Can I designate another word from this PLC to put on the data hwy?
Thanks Mike
Welcome to the Forum !
Please confirm; are you using the "Global Status Word" feature ?
That feature does only "publish" one 16-bit word from each controller onto the DH+ network to be "consumed" by all the other nodes on the network as part of the DH+ token rotation function.
If you need to move more data, you need to implement some peer-to-peer messaging using MSG instructions.
Need help getting a MSG from one data highway to another on PLC 5. One DH+ network is in one building and terminates at a desktop computer on a...
1,267
I have 10 A/B PLC 5's and 7 HMI's along with 3 computers on our data hwy. All the PLC's are messaging production data back to a computer that...
27
8,567
Hello everybody, I'm currently working on a project where I need to implement an IoT platform based on Microsoft Azure Cloud. Communication is...
50
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
74
62
