data logging and trending
glideratio
Feb 2009
US
62
Hi all,
I don't want trip twice on the same rake, I hope someone had a similar project,
I have the following configuration,
an HMI Panel is connected to a Mitsubishi PLC,
my task is to log the process data to the database,
both live and historical trends have to be available for viewing.
So the question are:
1) What is the best solution for this project?
2) Is it better to use a proper historian package or have some 3rd party OPC logger that would log the data to a DB (MSSQL, ACCESS, etc) and then some 3rd-party trend viewing software?
3) What to do in the event of network loss between PLC and OPC server ? How to manage this ?
Thank you
First ALWAYS put the rake away after the first time.
1. See 2.
2. IMHO it is better to use a dedicated Historian product.
3. A combination of the proper collector and Historian software will do this for you.
Hi Glideratio,
"an HMI Panel is connected to a Mitsubishi PLC" - Your task is to log live data and historical data from the HMI (or PLC) to a PC?
If this is the case, a scada software which has functions of logging data and collect data either from OPC Server or Mitsubishi PLC may be your best solution.
It also has historical data logging system, and functions to store data into SQL database.
You may take a look at the link: http://www.icpdas-usa.com/king_view.php
If you need help with it, I can help you get more information.
Luna / ICPDASUSA.
Hi Guys, I have setup some trending for a process that I'm working with using a Siemens Simatic OP270 Touch screen display. So far so good, but...
2,519
Hi everyone, We've came across a project for trending and historical trending from 2 Yokogawa UT temperature controller. The Controllers have...
5,145
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
77
Hi, Wy we log data in PLC using DLG instruction, when we have option to log data in HMI
82
Hi everyone id like to start by saying im not a PLC programmer so my technical terminology is limited. i would like advice on what software is...
301
