Data Logging for D2-260 PLC
anks
Dec 2004
California
66
I am using Automation Direct D2-260 PLC for my pilot study system and I would like to log data minimum for 2 weeks.
I am looking for local display type data logging device so that I dont require to connect my computer for reading the log values. Can you recommend me the type of display that will have more RAM memory and is compatible with my above PLC.
Thanks,
Ankeet
It sort of depends on the frequency of logging you need. I've done hourly data logs for a week at a time using the PLC's own registers. If you want more frequency, or if you want to have CSV files or other data export functions, then you are better off using Lookout Direct or a similar HMI software product with a dedicated PC. That's the route we went for a similar problem.
Another option is to use a Basic Co-Processor module, and you can create your own data logging in it. I'm not sure what kind of file handling it provides, though, but the catalog refers to "retentive data storage and retrieval". The WinPC might also be an option.
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
88
Hi, Wy we log data in PLC using DLG instruction, when we have option to log data in HMI
97
Hi everyone id like to start by saying im not a PLC programmer so my technical terminology is limited. i would like advice on what software is...
318
Hi All, I am looking for recommendations for a data logging software package that can be used for a simple 1 PLC installation. The installation...
1,419
Hello all, I am working on a DA70A flex edge data logger. I am it communicating with a computer on the network. I can ping it and everything looks...
398
